rjdmmfl1 »
https://forums.nicoclub.com/rjdmmfl1-u77059.html
Tue Mar 03, 2009 11:22 am
what type of system are you running? Do you have a factory battery or dry cell high amp battery? The easy thing to do would be to take a voltmeter and test your battery ...
1. with the car in the off position,
2. with the car on egine running, no music
3. with the car on, engine running, music at your normal (or loud) listening level
If you have a factory battery, my guess is you've started to run down the battery. If it isn't holding the proper voltage at rest, or with the engine in idle, that may be your problem.
Also, it depends on what type f underbody and LED lights you got. If you got LEDs, then that shouldn't be your problem as they draw a minimal amount of power from your system. If you got neons or cold cathodes, then YES, thsoe are DEFINATELY contributing to your problem. Remember, EVERY additional thing you do to your car that requires power is gonna be a drain on your electrical system. Your system is only as strong as your weakest link, and if you have the 2.5 and a factory battery, then your 115amp alternator and the battery are by far your weakest links!
