I'll post up some pics of what i did it's not the cleanest but it was free. i got all the parts from where i worked.
this pic is with the cover on. all i did was cut the end of the old battery terminal off at the terminal and attach an o ring connector. i attached the same o ring to the new battery cable and to the wire going to the fuse block. now my terminal block has a built in fuse which is a must in my oppinion as the starter will draw more power than it used to and you dont want anything getting dameged.
Without the cover.
now i also had a question about the relocation of the fuse box or boxes i want to relocate both the left and right ones does anyone have pic's of this?
ohhh and here are some pic's of my wiring harness. i re did it as i did not like the factory setup. it's not 100% done yet just want some oppinons.
as you can see i moved the fuel injector harness and the crank angle sensor. the right side by the turbo is what im not sure about and i want to move my fuse boxes. so there it is.
P.S. i know my spelling sucks.
