TurboTuli »
https://forums.nicoclub.com/turbotuli-u7884.html
Thu Jan 13, 2005 10:43 pm
Hey,My car wouldn't start and first signs pointed to starter, but when I had a towtruck jump me it started up fine. However a few minutes later after letting it run, the lights started to dim when I did anything the required electricity(roll down window, step on brakes) and then it died. I'm told the alternator is bad. I also had the battery tested and the guy said he couldnt get a good read ie. there was something wrong internally.
I am running dual 12" flexalite fans off a temp switch, so they aren't running all the time, and I also have a stereo system with a 650w amp running my sub. So my question is, do I need a better than stock(80 amp) alternator? And should I get a good battery? A shop i talked to said they can install a 105 amp alt for 200, but i can get stock for 80 and install myself. Let me know what you think...
