Damn Zozo...beat me to it!zozoka1212 wrote:It could be your terminals as you said. Also not sure if you noticed. 4drmadness had similar issue.
http://forums.g35club.org/zerothread/377613
zozo
If the battery terminals are clean it could still be a defective battery?Beancooker wrote:So I've been having really "cold" starts lately. I figured it was exactly that, the cold weather and ethanol that is now in our gas. This morning I realized it is something much more crappy...
It barely started. Like dead battery barely started. Once started it was great. So alternator is pretty much out of the picture. I figure had it been the alternator, the car would have been dead before I got to the top of the street.
Battery... I just put a brand new Optima Red Top battery in 13 months ago. It shouldn't be crapping out this soon.
Guess after work, I'll be checking/cleaning terminals and having a battery tested.
Nothing other than a grounding kit has been changed on the electrical system, and I don't think that is the culprit.
tollboothwilley wrote:SVT
buy yourself an optima battery so you can have the 4 year warranty
So, there isn't a known problem with 04's or any coupe 'eating batteries'??SteveTheTech wrote:Have you ever had a charging system test performed?
I would say if you are really curious you can do a parasitic draw test to see what you amperage is at when the computers go to sleep.
Will check with my mechanic buddy about doing a test!! Thanks!!SteveTheTech wrote:I would not say there is an issue with the 04 or any year eating batteries.
Nominal draw is ~.05mA and that is not enough to kill the battery. I do not personally prefer crap batteries, I only use Interstate and have never had problems.
+1Jacko3 wrote:Yep! The G loves cold air---its a different beast when it is cold.
I'll be taking the car over to Batteries Plus today and have them test for dead cells.Tampa G35 Sedan 6MT wrote:y don't you buy a new battery and see if it helps... if it does then you can take the new one back and have them exchange it for a new one?
DJ
BrandAidDesignG35 wrote:stealership.
$42. an hour is highway robbery.SteveTheTech wrote:
Hey we're not all here to rob you blind.
