Gerardjg »
https://forums.nicoclub.com/gerardjg-u36599.html
Sat Aug 12, 2006 5:58 am
When I turn on my ignition with out starting the engine my battery light is not on. I do not think I have ever seen it on since I owned the car. I removed theinstrument cluster and checked the bulb it tests fine with a 12 volt power source. I also performed the trouble shooting in the fsm which has you remove connector SL from the alternator and ground L. The results of this test tell me to replace the bulb. Should I go to the istrument cluster next and check diodes and resistors or is this an alternator problem?
As always thanks in advance
