Antharian »
https://forums.nicoclub.com/antharian-u66507.html
Sun May 27, 2007 9:11 am
About 3-4 times per month, when I go to start my car, nothing happens. The first times this happend, I thought the battery had died. When I replaced the battery, all was fixed. However, only 2 days after the first battery replacement, the same thing happened again.
When I detach the negative battery lead, and reattach it, all works again fine. The Radio also seems to be part of this same sympton. The radio will go blank, and the power will not go on to it. However, after removing and replacing the negative battery lead, the radio works fine again for several days before it stops working and needs the "battery" trick done.
Any ideas?
-Travis
