Skibane »
https://forums.nicoclub.com/skibane-u40096.html
Thu Mar 12, 2009 7:29 pm
Starting/Lighting/Ignition ("SLI") batteries don't tolerate deep discharges very well - They use thin plates that are capable of delivering a lot of current in a relatively compact, lightweight package, but those thin plates are also prone to cracking and buckling when the battery is heavily discharged.
Best solution is to use a trickle charger (like the Battery Tender/Minder that '96 mentioned), or a solar battery maintainer if the vehicle is stored where it gets plenty of sunshine. (Note that the Q's dashboard cigarette lighter socket is disconnected from the battery whenever the ignition switch isn't in the ON or ACCY positions, so the lighter plug that is supplied with most solar maintainers must be discarded in favor of some other permanent connection to the battery).
It's also nice to have a battery that will tolerate heavy discharges without suffering permanent damage. 4WD'ers and RV'ers often substitute deep-cycle ("RV/Marine") batteries for this reason - These batteries have thicker plates that don't deliver quite as much cranking current as their SLI counterparts, but they'll tolerate many deep discharges without croaking. The Group 24 and Group 27 sizes are commonly available - the Group 24 can be squeezed into a Q's engine compartment without much fuss.
