The material I removed ensured the diameter and shape stayed consistant through all 4 ports. I'm certainly no engineer and wouldnt begin to speculate flow patterns or rates... but I can tell when there is casting flash or when material should definately not be there... as the other ports dont share its shape. 80 percent of the material I removed on the exhaust side was do to the gasket matching. And then I only went in about 3/4 " to remove aluminum. There was no step in this process... it was more like a cliff
. The head size was up to 3/16th's smaller in alot of spots than the head pipes are. I also spent a lot of time flapping the shiz out of it as well to polish it.The intake side is also gasket matched and flapped with 80 grit to remove flash and give it a much smoother approach to the valves. Yes, I was very careful on the intake side to avoid making it too smooth so it wouldn't make fuel seperation issues... This whole process was closesly watched by my machinist who has built race engines for more than 30 years.
As for a step, I remember reading years ago where in motorcycles or other engines that have the exhaust header make a quick turn down that you must flatten out the port on the bottom side to quicken the flow so the exhuast velocity doesnt slow down on the bottom.
Besides, It's only the head. If the PnP didnt do right by the other mods... I'll replace it. I wont know until next week when the new cam is installed if the PnP provided any benefit. However, I have enormous confidence in my Machinist and his methods.
-Ric
