chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Tue Jan 17, 2006 7:30 pm
Hello, ive been working on a turbo setup for my s14 and almost have it all together (I think). I dont have a wideband and id rather just pay somone to make it run right since I have no experience with fuel mapping etc.
this is my setup
iap manit3 super 60tial 38mm, top vac port connected to compressor housing, the one on the side is open. has .5 bar spring, no boost controller.12x24 ebay fmiccustom 2.5" ic pipinggreddy rs bov, not recirculated, on throttle body side of piping, vac line connected to the vac line array near intake, other 2 are plugged up. the 2nd small vac line outlet on the bov is open.sr injectorsstock fprsafc-IIiap downpipe with o2 sensor that is probably burnt out3an feed line with no regulator10an drain lineidle air line tapped into right before the tb
maf is located kindof close, like 3 inches or so away from the compressor inlet, is this a problem?
firstly, does anything sound wierd or sound like it needs to be changed? does it sound like im missing anything?
second, im going to get my downpipe welded up very soon (waiting on the flange to get here) and i want to start it asap
im wondering what kind of settings i should mess with on the safc and timing to help the car drive to a dyno without sputtering along at 1500 rpm with my hazards on the whole time.
thanks!
heres a couple pictures
