S13Dreamin’ wrote:Hey guys, im new to the forum. Im wondering if my mod list is a good one for a basic motor swap into an s13. Ive added up all the costs (2500 for a clean blacktop, 1200 for labor) and I will have about $2000 to mod with. I want to have a tasteful, well balanced car. No turbo swaps w/ stock brakes kind of deals. Heres my list (from 240sx motoring).
100- Intake500- Apex NOIR cat-back150- High flow cat300- Exedy stage-1 clutch150- Clutch lines/ brake lines, brake pads100- Some turbo timer w/ boost meter200- Tein s. springs300- Shocks
Total: $1800
As you can tell, i'll be running the stock sidemount, stock radiator and stock boost for a while till the next stage. What do ya'll think?
Only new intake you'll get for $100 will be generic, Get a straight pipe and wait to buy the cat until you need to smog it, You don't need to replace clutch "lines", just get new master and slave and only replace the 1' section of soft line by the slave with ss woven, screw the turbo timer and get a boost gauge instead, Don't buy teins, get eibach or H&R or something if you really must. Don't forget basic maintenance like water pump, thermo, plugs, gaskets, motor and transmission mounts, etc...It can add up quick.
