S13240 wrote:I was wondering if I can tee the wastegate to the big vacuum line that goes to the bypass valve/bov? I know that it's suppose to go to the ic piping, but I was wondering if this is possible since the stock sidemount pipings don't have a nipple anywhere to connect the wastegate line to.
Also I noticed that there's a little nipple on the stock sr intake and i was curious as to what goes to there...
yes you can tee there. the stock pipes have a place by the radiator on the left side. its on that plastic pipe that goes to the throttle body.
you need to clairify the nipple you speak of.
the little nipple on the throttle body goes to carbon can. the other two go to the fuel reg, other fitting on carbon can, and wastegate if you wish, and bov. the only other nipple i can think off is the brake booster line on the back of intake nearer firewall.shaun
