BASIC....setup.
thekage
Car: 98 Dodge Caravan
98 Dodge Intrepid
I was thinking of a t3 or a t25Log manifoldcustom piping370cc stock silvia injectorssr20det smicSafc
This is for the basic basic turbo setup. I am on the tightest budget.Maybe 5psi tops for now.Any problems? What else would I need? any words of wisdom
nizmo240sx_22
Car: 1992 Nissan 240sx Hatchback SE
All I can say is don't cut any corners. Cut the engine flange, get t-bolt clamps the first time, take your time on the whole thing and you will be a lot happier. Don't forget to add in this to your cost:- Oil plumbing (jgs prolly)- Clamps, connectors- Make sure you're clutch can take the extra power- Don't cheap out on gauges (atleast oil and boost)- Retard the timing.
Hope this helps.
-Marcus
fiznat
Car: Grown up :(
-for the piping you will need silicone or rubber connectors (try cutting NAPA radiator pipe into sections for a really cheap option)-dont forget to include an upgraded fuel pump so the fuel will be there when you need it-you're going to need lots of small things: think gaskets, fittings, and flanges, they add up.-Planning on running a blow off valve? you should.. a 1G DSM blow off valve is a cheaper option-Are you planning on relocating your battery to make room for IC piping? That's a kit, or a slim battery maybe? Think about IC routing and all that
Theres definetly alot more but I have to go to work now and dont have time... Someone else on here should be able to help out more. Just understand that this WILL cost more than you think it will... always does.
240marcuSX
Car: E34 525i
E46 M3
oh my god that is a huge trubo fiznat!!!
also kage, go with the t3 if you can.
thekage
98 Dodge Intrepid
for fuel managment....FMU or a SAFC?on a tight budget...
Drift Machine
Car: 1991 KA-T 240sx
I would go with the SAFC, you can find them for cheap on Ebay. But going into a turbo project with a tight budget isn't always the best idea, I would save up money and wait until you have a 'flexible' budget.
WDRacing
With no money for a wide band O2 meter or dyno runs, just use the 8/1 FMU. Even I'm using one till I get my othe rpieces together for the big boost. You only use stock injectors with the FMU though.
The whole project can be done for under 2grand if you buy all used parts and are a big DIY kinda guy. Home Depot and Ace Hardware are your friend. Use 2" intercooler piping from Summit and you can use radiator hose for weird nebds as well as pipe connectors, which saves you quite a bit by the way. For a low boost you don't need Tbolt clamps, just make sure the end of each IC pipe has a weld bead or some JB Weld applied to give the hose clamp somthing to bite on, I ran 28 psi in my Skyline just like this.
If you've got access to tools and a welder your golden. Best of luck, if you need and other help post away or shoot me an email, [email protected]
thekage
98 Dodge Intrepid
thanks a ton everyone... lots of great info on here!What about a manual boost controller? cheap alternative to an electronic unit? or a good (inexpensive) alternative?
thekage
98 Dodge Intrepid
this is my first turbo project.. and i have done a done of reading.. I think I have a good grasp of what I am going to do.. jsut some small things are sketchy still... like the vaccum lines? thier purpose...Where would a manual boost controller go in line at?Does the wastegate feed the bov? difference in external wastegate and internal wg?thanks again..!
drifts14x
Car: Cars, Motorcycles, Drifting
I have a 1g DSM Intercooler if you want it to buy it for your setup, looks good, almost like what I have, Go JGS for your manifold, because they are good for budgeted people like yourself. Be careful and don't buy bad parts, ebay is your friend. Good luck
