Basic Question: Noise in Reverse
AK951
Car: 93 240SX SE
Hi all- I'm new here though I've had my 240 for a while. I was browsing around and I like it here.
I have a '93 and when I reverse it often makes this sound that sounds like I've hit something. If I keep on reversing it stops again- so it's like a bump or a "SCRAPE" rather. Does anyone know what it might be?
Dazzla
subframe bushings maybe?
hazukijitsu
Car: 91 240sx
I have the same exact noise with my car also. I notice it only makes the noise when I reverse with my foot is completely off the brake. The noise goes away for me if my foot is slightly braking while reversing, or I reverse with the Emergency brake up.
AK951
Car: 93 240SX SE
It might be the subframe bushings. Unless my new front struts have something going on.
Did you check it out Hazukijitsu? Is it something we should worry about a lot?
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
if its a clunking noise...def your subframe bushings. i replaced mine with aluminum bushings and never heard the noise again. now i just hear road noise and vlsd.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
splintercell wrote:if its a clunking noise...def your subframe bushings. i replaced mine with aluminum bushings and never heard the noise again. now i just hear road noise and vlsd.
QFTI had the same problem. I installed some peak performance subframe collars, now it just squeaks when I reverse and hit the brakes. I know, I know...I need to actually replace the WHOLE bushings.
