ka24det-power »
https://forums.nicoclub.com/ka24det-power-u23226.html
Sun Dec 12, 2004 3:28 pm
What's up everyone. I have been reading this board for a while and because of that and the guys at ka-t.org I have built my first KA24DET. Bye bye GSR-T hello torque!
So here is my setup so far:
SSAuto Tubular Topmount manifold300ZX T25 Turbo, Int GatedWalbro Fuel PumpGreddy Type S BOVCustom 3" downpipePrecision IntercoolerHKS Coulpers and T-bolt clamps4' -04 AN braided oil line with a .065" oil restrictorCartech Adjustable FMU300ZX Fuel filter
Oh for the guys who keep cracking their SS mani's weld a support flange on the downpipe that bolts to the transmission and your mani won't crack.
Ok so I am use to the Honda MAP system, not a MAF so I have a few questions in general.
Q 1 ) I have everything installed and it runs pretty good right now other than it wants to stall a little when I drop the RPMs quick. For instance putting it in neutral and coasting up to a light.
Q 2) In order to get it to accel smooth I had to advanced the dist almost all of the way with the FMU set at about 8:1 ratio. This worries me - in a Honda you can't advance the timing AT ALL or you are asking for a quick death under boost.
I tried leaning the FMU out and retarding the timing but it won't run smooth past 4000 RPM. It starts to sputter. The boost is at 6 PSI. Is this normal? Also at 9 PSI set this way it is it starts to knock.
Q 3) My power dies after 5200 RPM is this normal? Could it have to do with my timing? If it is normal what is the best method to get it to breath/make more power on the top end? Gasket port head, JWT cams?
Feed my brain oh KAT tuners! I got some smack down to lay on a few SR's in town.
Thanks!
