Base SAFC Tuning...
SilviaSlydSydway
Car: 1991 Red KA-T~~~1989 White Coupe
Hey guys...Im finishing up my Ka-T project, but i need to know a base tune for my safcII that i can drive to the dyno for tuning. I have a walbro, sr 370's, t04 turbo, and i want to run about 7 psi. Thanks
Craving4Boost
Car: 91 240sx fastback
-27% across the board. Doesn't really matter what you put for HI map settings because I hope you don't boost on the way to the dyno. Do you have a wideband sensor? for a little set up with 370cc injectors, I reccomend just using the SAFC + Wideband and do a street tune. Make sure you retard timing via distributor or MSD BTM.
SilviaSlydSydway
yeah...i wanted to get a wideband so that i could just tune it up myself, but i have never tuned a car before, so i wanted to get it tuned and hopefully learn enough to do it myself next time. And thanks alot for the help.
