This is a NA, that I have plans for a V8 swap. It is the 5 speed. By sleeper I mean crappy paint job so you dont expect the full coilovers, full roll cage, and 6L Chevy hiding under the hood. Oh just because I haven't seen it said so far, the stock 300zx center caps will fit in the z33 rims.
Driver side is just barely rubbing on the splash guard on the front. It appears someone before me cut the shield and due to this it is grabbing the open end of the shield and pulling it back and forth as the wheel is turned. I should be able to zip tie it back for the time being just to clear. The bigger issue is that the tires are completely bald on the inside(somebody was running some stupid camber), so they will have to be replaced sooner rather than later.
Here is some basic pictures of the project.
