Auto_Editor »
https://forums.nicoclub.com/auto-editor-u243841.html
Mon Aug 03, 2020 7:36 pm
In January of 2018 the accessory idler pulley froze and broke the belt. At that time I had the whole assembly [11925-AL50B] replaced along with both belts.
Now the A/C compressor idler pulley is screaming like a banshee, having used its last drop of lubricant, and it does NOT seem like a "WD-40 job" or something that can be "repacked" with whatever was in it, even temporarily. [DO correct me if I'm wrong, even if it just gets me a couple of days' use...]
My lizard brain is telling me just to cut that belt, as the A/C hasn't worked since I bought her in 2006. But I fear that would mess with the tension being put on the other pulley as they are mounted on the same shaft coming off the crankshaft itself.
Ideally, I could just buy a new assembly, have someone take the slack off the compressor belt, undo the assembly's three bolts, slap a new one in, re-tension the belt, and Bob's your uncle.
If that's the way it works, great. But I'm getting three different options (not counting the individual parts). Parts.infinitiusa only lists the 11925-AG30A ($158.87), Infinitipartsdeal has the "old" part number [11925-4W000] for $115.81, but says the identically-priced AG30A won't "fit my application" despite clearly listing it as the number that "superceded" the 4W000. Oh, and diagrams list it as "11925M", just for funsies, I guess.
I don't mind paying for the AG30A (if it works) and the install is easy (other belt booked in at 2.5 hours). I cannot find an image of ANY of these parts, however, and the parts diagrams don't help for reasons stated.
Thanks in advance for your help, and here's to hoping that I receive your wise guidance before the pulley grenades and takes its belt with it...
