Banjo Oil Fitting
Shahee1
Car: 1993 240sx w RB20DET
Does anyone know what size the Banjo oil fitting on the turbo oil feed line going into the block???
BoostFab
Car: S13cp, S13fb, S14z
the thread on the block for oil feed line is 12mmx1.25
i have some adapters for braided oil lines ( fits AN-3 or AN-4 lines) email me for info.
burnin240sx
may I ask where you got your fittings. I'm thinking about having our ss line distro make me a line with a male m12x1.25 on one end and female AN -3 fitting on the other end. but i'm sure when i ask it will be more then it would be to make my own line with some fittings.
Wulfgang
If you take it to the right place, it'll be cheap. I got a local hose shop to make up a new P/S hose using the stock banjo fitting. He cut the banjo fitting off, drilled out the old hard line, brazed in a new hard line stub with an AN-6 fitting on it, and brazed another AN-6 fitting on the other end where the P/S pressure switch is located, all the while cursing the Japanese and their vehicles, the metric system, etc. Then he made up an AN-6 hose with swivel connectors to run from the PS pump (the banjo fitting) down to the PS rack (at the switch).
.... but he did a great job and it all cost under $15. Yes, $15, including the hose. He just charged me for the parts, with no charge for the brazing, cutting, etc.
I'm sure they could do the same thing with your turbo banjo fitting if you could find a shop to do it.
