Banjo bolt thread size ?
boostedef
Ok Im redoing the oil lines on my friends blacktop sr20det. For the return line Im welding a -10 an fitting to the oil pan and using a -10 line for the return. Im also doing the oil feed but I dont want to use a banjo fitting. Im going to use a -3 line with a 90 degree fitting on the turbo and I want to use a -3 straight to the block eliminating the banjo fitting. Do any of you guys know the thread pitch/size of the banjo bolt on the block ? I tired searching but couldnt find the measurements.
playbass311
Car: 1991 240sx
I THINK it is m12 x 1.25, but honestly I can't remember for sure.
boostedef
crap i cant find that size
