Banjo bolt?
captainfalco
Car: S14,MX83
I need one of these banjo bolt type deals. I know that a braided line would do a better job but I just need to get one of these to get me going.http://nissaninfiniticlub.net/...5.JPGAny help would do. I can't find anything like this at my local parts stores at all, let alone find anyone local who knows what the hell I'm talking about.
Shaefer Thomas
Car: 1992 240sx
Hey bro, there are alot of different banjo bolts on this motor. You should specify which one you need. If you get lucky, someone like SpeedRacer1 will post the part number for you. Then you go to your local Nissan dealer and order the part. If I knew the number I would give it to you but I dont. Also, there is a part number sticky thread. Check in there also, if you havent already. It might be in there.
captainfalco
Car: S14,MX83
http://i31.photobucket.com/alb...5.jpgI need the one that goes in that guy.
captainfalco
Car: S14,MX83
bump ttt
Geno750
The bolt he is after is the banjo bolt for the coolant hardline going from the s14sr water neck. If that is the same size as the banjo bolts that are on the s13 blacktop then I have an extra one.
captainfalco
Car: S14,MX83
I have no idea if the bolt is the same size or not but it won't hurt to try it. What do you want for it?
Geno750
captainfalco wrote:I have no idea if the bolt is the same size or not but it won't hurt to try it. What do you want for it?
Cost of shipping, I have no use for it. If you can find a bolt that will thread into the neck, or don't mind taking it to Autozone to test fit some bolts into it to make sure they are the same. I'll post the size of the s13 blacktop one tomorrow unless someone chimes in and confirms/denies that they are the same size.
captainfalco
Car: S14,MX83
yeah sure, anything would help
Geno750
So what size is your waterneck bolt? Or do you want to just have me mail mine to you. Here is my e-mail [email protected]
captainfalco
Car: S14,MX83
email sent
