Jager »
https://forums.nicoclub.com/jager-u75972.html
Mon Dec 03, 2007 11:54 pm
you may have heard your spark plug taking a hit from the piston, dont ask me exactly how that occurred but ive seen that happen before.
but if its running crappy id pull the sparkplugs and useing a bore light or a flexible led light get in there and check the piston heads for dents, do a compression test, and also check the exhaust/intake manis for missing bolts, or cracks, and if your exhaust broke. those all can be loud and cause the engine to run like crap.
the chain check as well, my belt teeth shredded off and the belt itself stayed fine, the car ran for a while until it finished stripping the last teeth on the belt. boy that screwed the timing up :P
