balljoints
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
94fordman
Car: 86 nissan 720
hi new but not new to site i have an 86 nissan 720 and balljoints are bad anyone know if its possible to take balljoints out without taking arms off
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
I have an 85 and they bolt in. Check for two bolts on the inside of the joint.
94fordman
Car: 86 nissan 720
book calls to take off cont arms
PEZi
the book calls for removal of the torsion bars as well from what i remember... its not necessary
94fordman
Car: 86 nissan 720
did balljoints vehicle still pulls to left and bumps a bit what could cause these symptomes
damn
Car: 1986 Nissan 720 z24, Automatic trans
94fordman wrote:did balljoints vehicle still pulls to left and bumps a bit what could cause these symptomes
What was involved in removing them?
PEZi
the alignment may be done wrong... meaning they don't center the wheel properly before aligning it which would mean it pulls when the steering wheel is centered... if the alignment is done right... it could be a wheel bearing
85NIS720
Car: '85 Nissan 720
I'm actually in the process of replacing a ball joint and spindle on my '85, so I guess this post is useful to me as well. My spindle was bent to heck and back, so we just cut it off and my ball joint unbolted pretty easily. We haven't replaced it yet though.
94fordman
Car: 86 nissan 720
found it easy to support bottom arm with bottle jack and lowering it to get top balljoint to go in
damn
94fordman wrote:found it easy to support bottom arm with bottle jack and lowering it to get top balljoint to go in
If the truck is still pulling to one side try checking your tie-rod end link's for damage.
Return to “Datsun 720”
