pws »
https://forums.nicoclub.com/pws-u173996.html
Mon Mar 21, 2011 12:10 pm
So I had some noise at speed so I checked my 97 J30 and found the driver side wheel able to move up and down and left and right. The other wheel didn't move at all. So I went and got a junkyard lower control arm from a 96 J30 with 120k miles on it. (tried to find new balljoints but they don't make them and dealer lower arm was $308 out the door.)
Once I put it all back together the tire no longer moves up and down but still moves left to right when you grab the tire and move it back and forth with hands on the sides on the tire moving it from front of car towards back of the car. I took the tire off and it seems like the whole strut tower shakes left to right. Kinda looks like its moving from the balljoin area.
The noise at speed and when you hit a bump is now gone. What else could be causing the right left movement? Thanks
Edit.
GF called me and said it is making the same noise. So is this balljoint bad too or what else could it be. I see it moving at the balljoint area where the other side doesn't move at all,
