ballbearing turbo question!
domiballa
Car: 1993 s13 hatch
okay i was searching around but i just want to hear some answers for the peace of mind.. i just installed an s15 bb t28 and i started it for the first time today open downpipe.. it sounded like it was sort of scraping a little?? is that normal ive never heard a ballbearing turbo open downpipe so i was just wondering.. the turbo was in mint condition no shaft play so is that normal?!?
newdude1
Not to thread jack or anything, but is there anything special you have to do on first start up with a new bb turbo?
Ramonesfreak2010
Car: 1993 240sx Hatch
^^^I remember I read somewhere that you have to crank the engine a couple times so the turbo gets lubricated with oil? Not sure if thats it. Adrians_S13 said it.
DanThaMan
Car: 1993 240sx
they sound like really quiet skateboards to me.
JaxS13Racer
Car: 1993 SR20DET S13 fastback
You shouldn't have to do anything special for a bb turbo. At most just let it idle for a few minutes to get everything lubricated, but that should only take as long as it takes for your engine to warm up. As far as the open down pipe I never heard anything that sounded like scraping with mine, just high pitched whistling from the wheels spinning and the air moving. If there was no shaft play then you should be alright.
domiballa
Car: 1993 s13 hatch
Thanks for the replies.. Im guessing it probably just wasn't lubricated yet.. I let it idle for about 10 secs then noticed a leak and shut it off.. Next time ill crank it a few times first.. But im going to remove the inlet pipe and spin it manually just to make sure
