SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sun Apr 03, 2005 9:44 am
Which model are they, and do you have at least enough spring preload to keep the spring seated? Also, when you put in a stiff suspension, all of a sudden every slightly loose steering and or suspension component are subject to jarring. Maybe you have another problem? Spend some time under the car looking for the obvious problems. Bearings, worn TRE, TC rod bushings, etc..
