ball joints and tension rods
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
anyone ever do these????any info or pointers would be great
yodawill2000
Car: 94 Infiniti J30
Tension rods are a snap.http://www.fuzzycats.com/docs/...t.pdf
Ive given Carlos heck about it saying Tie rods lol
Cant help ya on the ball joints .. never been there .. yet
J30inthe sun
Car: 1997 J30
I just had my front ball joints replaced. They are intergrated into the lower control arm (@ $190.00 each side), you have to replace the whole unit. The one plus from the whole thing is that the inner bushings are replaced as well because they are part of the control arm unit.
Manufactured profits.
yodawill2000
FYI if you have a press you can replace just the Tension rod Bushings for ALOT less
kbflip02
2006 Infiniti G35x
how would one go about doing that with a press?
yodawill2000
Press the old bushing out , then press the new bushing in !!
The rod itself should be fine unless it somehow got bent.
Modified by yodawill2000 at 8:29 AM 3/26/2009
kbflip02
2006 Infiniti G35x
so heres what i apparently need for my J...both inner tie rods @ 241.87 ea, both other tie rods @ 64.46 ea, both lower control arms including ball joints @ 258.70 ea, tension rods @ 222.86 ea which brings my grand total to just under $1600....put in a call to Joe and Leon @ everythinginfiniti.com and they quoted me @ $1200 shipped overnight...so much for doing my shocks and struts right now...oh welll...my point im trying to make is everything infiniti is the way to go for OEM parts!!!!
J30inthe sun
Car: 1997 J30
kbflip02 wrote:...both inner tie rods @ 241.87 ea,...
I just replaced the full rack & pinion unit which included the INNER tie rods & it was $350.00.
Modified by J30inthe sun at 7:19 PM 3/26/2009
J30inthe sun
Car: 1997 J30
I meant inner tie rods... corrected above.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
J30inthe sun wrote:I meant inner tie rods... corrected above.
Where did you get the rack? also was it as easy as it looks in the manual to change.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
kbflip02 wrote:how would one go about doing that with a press?
You buy the new bushings take the rods out and bring them to a machine shop and they will R&R the bushings for you . I have access to a hydraulic press and did my own, it took close to 5,000 PSI to get the old ones out. The procedure is in the manual.
J30inthe sun
Car: 1997 J30
Gerardjg wrote:Where did you get the rack? also was it as easy as it looks in the manual to change.
That's what my shop I take my car to charged me. tHERE ARE 2 bushings for the rack that you might as well replace them while you are at it, I think they were @$25 a piece.
Look at rockauto.comhttp://www.rockauto.com/catalo...up,26
autozonehttp://www.autozone.com/autozone/catalo ... tid=354966
