Ball Joint Torque Specs (front)
Zion8561
Car: 92 Nissan S13 Fastback
Does anyone know the torque on the front lower control arm ball joint? My Chiltons and the FSM had the specs for everything but the ball joint. I torqued to the spec for the rear ball joint...52ft lbs.
The new ball joint, control arm bushing, and tie rod ends made a huge difference in steering response. This was well worth the time.
Please post if you know for a fact what the correct torque is.
