princess auto. its their own brand. vancouver canada.fredbyte wrote:Where did you see them on sale for $16? And who was the manufacturer?Thanks. I'm in Bellingham.
I just got an oversized one so never makes contact with the ball joint itself, and with that tool its pretty hard to use in all situations, like trying to pop out the ball joint on the rear lower control arm.nissanman04 wrote:The fork has worked for me, but if I wanted to re-use the ball joint I'd definitely try that tool.
This is what you should do.jdm_master_X wrote:threading the nut flush with the ball joint stud and then smashing it with a mallet has never failed me.
the method i was referring to is similar to pounding wheel studs out of the hub.!Zar! wrote:This is what you should do.
Most people fail to put the nut on and then destroy the threads.
Using that pickle fork destroys your balljoint.
The BEST way to remove an old/new tierod end is to
1. Spray PB-Blaster.
2. Unthread tierod nut flush with the bolt.
3. With a mallet hit the side of the spindle where the bolt goes through.
4. Place a rag over the nut.bolt and lightly tap with a mallet.
5. Go install new tierod end to manufacturers tq specs.
6. Brag to your gf/wife/bf/$5 wh0re and watch those panties drop in amazement of how easily you handled your steeze.
thsi si what i woudl do, except i pounded mine out without putting the nut on. i really don't care about ball joints i'm throwing out thoughjdm_master_X wrote:threading the nut flush with the ball joint stud and then smashing it with a mallet has never failed me.
