Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Sun Jun 13, 2004 9:18 am
I'm not sure what you are calling the 'drift'. I used the instructions on the box...
Anyway, the ball joint gets pushed out going down (towards the ground), so that's where the collector needs to be (the big ring)...that's why it has to be larger than the base of the ball joint. On the top is a saucer looking thing that slides over the threaded part of the ball joint. Sorry if this is a little vauge, but IIRC there was a saucer thing on top, ball joint, collector ring, and another saucer sized for the 3 different collector rings.
