Does anyone know where you can buy replacement ball joint boots? I tore two of the boots on the LCA's when removing it from the brake knucke/spidle part.
Also when dropping the gas tank does the filler tube that runs all the way up to the gas door need to be disconnected at the base of the tank or does the tank drop with the entire tube?
