ball joint boot - ripped - need to replace boot but where?
RoyBatty
Car: 2001 Sentra 2.0 se ( B15 )
Howdy Folks:
discovered a ripped ball joint boot when replacing CV boots
anyone know where I can get a new boot -
cheers:
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
I recommend replacing the whole ball joint. PITA, but at least you will have piece of mind.
RoyBatty
Howdy Red:
Cheers for the reply :
as you may be aware - the ball joint comes as one unit with the lower control arm - cannot just replace ball joint - as LO CO Arm is stamped steel - the boot is going now - if I can replace the boot a.s.a.p I think I can avoid 200$ now
Cheers:
slickser24
Car: 96 200sx se-r
yeah your better off replacing the whole joint. i did mine fore about $20 a joint. if the boot is torn dirt may have damaged the the ball of the joint and you may just have future problems.
RoyBatty
Howdy Slickser:
I agree with replacing the balljoint as well- as I stated the local GOOD JAP IMPORT parts supplier tells me the ball joint is a non replace- stamped steel lower control arm will bend when pressing in
so until I find out for sure if the b15 - 16" rims do not have a replacement ball joint - I will have to just make sure I clean it good and replace the boot
I did have mentioned to me that Moog makes a replacement ball joint for a b14 - so I will check into that
Cheers:
slickser24
Car: 96 200sx se-r
oh i thought it was a b14 i didnt know that the b15's are one unit....my bad but good luck to you!
RED_DET
Vendor
2011 Infiniti G37x
I didn't know the b15's were one unit as well. I will look on the wifes car later and see.
RoyBatty
Howy Red:
It is interedting - On a few pages I grab parts from - they all list the lower Control arm as only means of replacing ball joint
yet on another site someone told me that MOOG made a replacemet ball joint for a b15 16" rimand I did locate this - so who can say - if this boot I just put does not work - I will try the MOOG ball joint and see
Cheers
