BAG KITS FOR Y33
NICO's V.I.P. styling forum.
Hermz702
Car: 98 infiniti q45
ANYBODY KNOW WHERE I CAN FIND DEALS ON AIRBAG SUSPENSION KITS FOR Y33'S???
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
Welcome to NICO and the VIP Forum!
First of all, you are probably not going to find a "deal" on air, unless it's used. Second, if you want to get out cheap at all, then stick strictly to your normal scheduled maintenance on the Q. Even then, you could look to spend roughly $3K give or take, each year in maintenance.
If you come across something used that you like, go for it. I will say, from my own experience, nothing in this form is cheap. If it is, then it's probably "cheap". There are little to no "less expensive" options for whatever you're looking for. Most of the ones you may find that are, are frowned upon for the most part.
So, all that in mind, welcome, and feel free to search and ask whatever!
Hermz702
naw dude i saw on one of the vip forums airforce suspension kits for around $2k which i think is reasonable....just cant find that post anymore....but thanx anyway dude :bigthumb:
dzznuts671
Car: 1999 Q45t
you could do the airforce susp but know that you would have to cut and weld the strut to your spindles. it is not just a simple plug and play. i havent heard much about the airforce susp but most people i know are either running the UAS or Airrunner. There are pros and cons to both. Def do a little research before jumping on any. There are also other options like the coilover/cup type. But i guess it just boils down to your preference. Hope that helps a little.
and i agree with Jltibbs VIP is def not a poor mans sport.LOL Nothing cheap about going VIP and def not cheap to maintain a Q!
Btw. Any bigger pix of your ride? What color is that? Are you in vegas?
Hermz702
yea im in vegas and yes i know vip is expensive but i heard airforce is good and at a good price....and a lil faster than airrunner but i know airrunner is the best because of the ride....the color is espresso kinda like a rootbeer color (stock) as for pics i'll post some later but its nothing special since its stock but thanx for the reply dude
Hermz702
oh and yea im a rookie lol how the hell do u put up pics?? under signature right?? but i dont know how to do the code :confused:
dzznuts671
Car: 1999 Q45t
we might have a little Cima meet this thursday if you want to check it out. Most likely it will be Aloha Kitchen on Spring Mtn. Hit me up on VSC. Same screen name. Hope to see you around!
Hermz702
yea my boys told me bout it imma check it out...thanx bro
dzznuts671
Car: 1999 Q45t
all the Q's are going to meet up at Jollibee on Ft apache and Sahara at 9pm tonite! Might roll to Aloha later on.
Hermz702
mines stock tho but yea ill be at aloha kitchen wit my boys....i wanna see your ride and the rest o the y33 bad boys hehe
owinbush
Car: 1998 Inifinit Q45
2009 Nissan Cube
universal air suspension. check em out. I mounted their bags over a set of nismo coilovers. Relatively simple little fabrication and good results.
BLACKonBLACK98
Car: Q45, LS400, STS-V
the best bet for y33 suspension imo is first converting to s13/14 coilover suspension. you can add air (uas or cups) from there if you want.
uas over stock struts is another option but uas is best over coilovers. airrunner is a big money, low feature (but simple and reliable) option.
Hermz702
THANX GUYS...OWINBUSH YOUR RIDE IS HELLA CLEAN MAN!!
dzznuts671
Car: 1999 Q45t
Yo hermz702 we are going to have a VIP meet at Durango and Flamingo at Fukuburger on wednesday nite around 8pm. Most of the Q's will be there. You should check out Vipstylecars.com also. we post most of the meet times on there. Hit up my boy charles if your down. Just txt him 7024096597. hope to see you out tomorrow nite!
peace!!
owinbush
2009 Nissan Cube
BTW.....^^ is right. the best way to deal with suspension for the q45 is to update to an s13/14 suspension. I did the conversion and used 14 coils. with UAS bags subbed in as the springs. Rides a little rough due to the coilover selection but I'm aight. Eventually I'll upgrade to some difference coilovers and soften up the ride. Even running this route I spent just over 2k. and I did all the work myself.
Return to “VIP Forum”
