Scott Buwalda »
https://forums.nicoclub.com/scott-buwalda-u7159.html
Wed Dec 27, 2006 2:23 pm
Help me guys, this is a new one for me.
Noticed recently the brakes on my red S14 were mushy, so I decided to finally get around to putting my 26mm Z32 brakes on it today. Put the passenger side on first, and took it for a ride...nice braking improvement. Was driving along, and noticed it getting mushy again after a few minutes of HARD testing on the pedal, and by the time I got home, you could put the pedal to the floor before the brakes engaged. Noticed oil leaking from the reservoir cup (around the seals)...removed the reservoir and pushed it back in, cleaned the area off, and worked the pedal a bit, and no more leaks.
I figured it was an air bubble in the master cylinder, so I purged that valve too---nothing but oil.
Went on now to the driver's side with the Z32 brake swap. Both sides were thoroughly purged with a hand-held vacuum pump...extensive purging until nothing but oil was returned from the purge valve. Buttoned her all back up, and before starting, pounded the brakes, and within four or five pumps, you couldn't move the pedal any further; rock solid. Start the car, and the pedal drops to the floor. The brakes do work, just not good, and there's a lot of pedal action before they even begin to engage.
I am thinking master cylinder. But why would this happen only when the car is running? I also noticed that the reservoir cap rubber gasket is bad, and I removed it...perhaps this is a problem? Help anyone? Need to get this thing on the road tomorrow.
