Ghostinthenight »
https://forums.nicoclub.com/ghostinthenight-u49536.html
Tue May 24, 2011 1:39 pm
I'm wondering if my problem may be from a bad wheel bearing. It started not too long anfter I was in alton, IL and went over a deep pothole at very slow speed. The impact sounded titanic but an immediate lookover showed no damage to the body or frame. I did notice the drive back to Arkansas the passenger rear wheel 9 the one that went in the pothole) felt wobbly on the highway. I assumed that this was because the person placing the new tire (done just 5 minutes before impact) on it did a bad balance job. A week later I noticed that the wheel makes a loud chirping sound that sped up with the tire speed. The problem got worse very rapidly (a noticable change after only one commute). Is this a bad wheel bearing or something worse? I noticed only the slightest hint of wobble in the rear axle but the other side has the same and there are no problems with it.
Thanks.
