180fan wrote:Awesome. I'm sure you can do the water pump job. That and flipping your mechanic that tried to ream you a new one, the bird.
Damn that was simple lol. It took me about 45 minutes (20-30 minutes figuring out how to take off the fan, 5 to take off the water pump bolts, then another 10 to drain the antifreeze because I forgot to do it first )
Ok, my water pump looks good to me (I was right after I let the car run. It was leaking from the bottom):
EDIT: While I was pealing the silicone gasket off, I thought a piece of it had gotten tangled around the inside wheel of the water pump cause it was kinda dangling and broken (wasnt one solid piece), so I peeled it off. So I guess that means I need a new water pump.
Modified by Neejay at 5:11 PM 3/1/2005
