TheColoradoQ wrote:Engine idles a little rough and seems to be a little high at 11-1200 rpms (idle screw is all the way out but this is as low as it goes) but feels very smooth in gear and under load, about 700 rpms at idle w/o a/c.
Maybe a type-o, but out is higher, in is lower. Turn the screw all the way in (clockwise), then back it out 2-2.5 turns... If everything is clean you should be at about 650RPM.
High idle may also be incorrectly adjusted throttle cables. There should be a couple mm. slack in them when the car is fully warmed up. If they're too tight they'll have a tendancy to bind. You want to get this corrected since you're beating the transmission pretty hard putting it into gear at that idle speed.
Would you describe the idle problems as a "bouncing" feeling at idle? If so I'd suspect a dead cylinder (probably due to a bad injector). They can ohm fine and still be clogged. You might want to work on the idle problems and then get a power balance test to see what's going on... it may be time for an injector flush.
Good luck!
Heath
