They are Pirelli Centuro - must be about 4 years old. New brakes on rear - front rotors need to be turned, but the vibration seems to be coming from the rear. There is a small leak in one of the rear shocks, but not ready to replace yet - just 87k on my Q. I've ordered some Conti Extreme Contacts to replace the tires. Hopefully that will iron out the prob if its tire/wheel related. Otherwise I will replace the front rotor/brakes soon. Its funny because the vibration came on all of a sudden. Maybe I did lose a wheel weight. I guess I'll go check that too. The Pirelli's have never given me a prob yet and handle quite well for a T rated tire.Jesda wrote:What is the brand/age of the tires?
Both of these facts scare me!xmateo wrote:They are Pirelli Centuro - must be about 4 years old
While most of what you say is true and generally known in depth by the members of this board, the above is abosolutely FALSE. You don't understand the minimal sufficiency of speed rating test, you don't understand what happens to tires as they degrade over their lifespan, and you don't understand that tire life and safety performance have an inverse correlation.bigjimmy wrote:A touring sedan benefits greatly from a T or H rated tire compared to a Z rated tire. No more vibrations when cold and a much smoother, quieter ride. A tire capable of running at high speeds requires stiffer construction, in order to provide the necessary high speed stability & durability, and this comes at a cost. T and H rated tires generally last longer, ride better, and cost less.
My wife's 2000 FY33 standard was delivered with new oversized S rated tires. I cannot convey how poorly they handled and how bad the ride was. Very, very scarey. Dealer even drove the car for a week or so!Q45tech wrote:Pretty much every tire will pass an S rating. (Please note that I'm limiting the discussion to regular passenger car tires. Winter tires and light truck tires are a different story - similar, but different.) And T ratings are not much of a stretch.
So an S rating would - on the surface - seem to be adequate for use in the US where there are speed limits everywhere.
1.) You are WRONG and ignorant of tire construction - i.e., why does one tire merit a higher speed rating than another? Duh?bigjimmy wrote:1. My point was speed ratings do not mean a better tire. I believe I understood it better than you, they take a tire and spin it against a bar with a load for a set amount of time and if it doesn't blow it gets a rating.2. From my post, how could any sane person derive this?3. See #2.
I respect everyone on this board, and everyone’s opinion except MAXNIX.Go bag on someone who just signed up.
This is simply not true, unfortunately!bigjimmy wrote:It receives a higher rating because it can spin against a bar for a set amount of time without blowing out. Period, end of story.
Certainly in that they are used every day! Hopefully the airbags are not.Q45tech wrote:Probably more valuable than side air bags?
You really don't understand tires at all, do you? Care to name a Z or higher rated maximum performance summer tire with a "traction grade of c" or a "temperature grade of b"?bigjimmy wrote:Would you rather have a Z rated tire with a traction grade of C and a Temperature grade of B that costs $150Or an H rated tire with a traction grade of AA and a Temperature grade of A that costs $150?
Thanks to all for all the info. For the ugly banter, enough is enough!! I bought my Q with the T rated tires on it. I was later surprised to see this rating as I have always worn at least H rated tires, and these Pirelli's handled surprisingly good. The tires may be newer than 4 years (just a guess since I don't see them on the market anymore and I can't find the repair history at this time. Nevertheless, I did proceed to buy the V rated Conti's even before I felt the vibrations. I knew it was time! They will be in any day. Pray nothing bad happens in the mean time. I have slowed way down for now.szhosain wrote:
Tires start vulcanizing and developing micro-cracks after a few years. Although not extreme, four is a bit too long to go without changing them, almost no matter what the wear. I would certainly not do 105mph on them at all ... frankly, driving around town may cause premature failure.
Secondly, T-rated tires also implies (but not certain) that they do not have the load index for a Q - even the Y33 years - and the speed limits for these tires is lower than suitable for a Q. You definitely need to change the tires for at least an H rated (preferably V or W or Y or Z) tire as soon as you can do so.
BTW, I am fairly sure that your vibration and problems are due to tire failure inside the treads ... maybe some belt has broken. Please be safe and do not drive at highway speeds on them, if you can avoid it, and change them asap.
Z
He has them on his Q for the simple reason that Michelin Pilot XGT H-rated tires are probably stronger in internal construction, and after many miles, than most other companies V-rated tires and also, he does not reach or exceed 130mph in his Q as he is saying.bigjimmy wrote:"Now that I am running XGTH on my 15" rims, will never know what it is like over 130 mph."
So maxnix runs H rated tires. What a hypocrite.
Geez, Jesda, I thought you were my friend!?? I mean, ever since the sauna.......Jesda wrote:There are no low-rated Z-speed tires for inherent reasons.
Brian isn't the nicest guy on earth (LOL, an understatement) but he's making a good point here.
