Meaux »
https://forums.nicoclub.com/meaux-u23660.html
Sun Nov 13, 2005 5:22 am
94 Q45, 80K
OK, I'm jsut gettin to the last thing to do after the KS/Plenum job...I'm very slow......I used an ohm meter to temporially set the TPS idle switch.
When setting the TPS voltage at the AT control Box (#34,35) this is what happens:
Normal operating temp, @0.44v, Idle is at 1400rpm, and WOT (engine off) shows 3.45v. That's as high as it will go. Using the accel. pedal, it's even less.
While adjusting TPS with engine running, it will idle down @0.18v. (I'm assuming thats where the idle on-off point is)
Went back to 0.43v, idle back up to 1400rpm, completely closed IAC valve, for an Idle speed of 1000rpm.
Shut her down, closed the door, and killed 10 Coronas...
Bad TPS?
Thanks...
