JJ240 »
https://forums.nicoclub.com/jj240-u4459.html
Tue May 20, 2003 4:33 pm
cam timing would not cause you to have a 5k redline. In fact if you were off a tooth on the cams you probably wouldnt get your car to start due to lack of compression. And if you did you would most likely have valves contacting piston.
