Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Sat Dec 06, 2003 6:19 pm
Whoa... why does your fuel pump get a signal "directly" from the ECU now? All of the wiring diagrams I have seen show that the ECU (pin 18) grounds the fuel pump relay (to turn it on) just like with the KA. Even if you have a GTR with a special fuel pump control unit, the pump should still be powered via the fuel pump relay.
I have seen an air regulator on some of the RB20DET wiring diagrams. It is wired in parallel with the fuel pump, coming off of the fuel pump relay. Interestingly enough, it is not on the engine harness wiring diagram I have, but it IS on the general wiring schematic. So where is it located? I don't know. (Just like that little silver box on the passenger side of the engine bay... nowhere to be seen on the wiring diagrams, but it is clearly part of the engine harness.)
IIRC, the KA has an air regulator that opens when energized, but since it is made of bimetal, it closes after it heats up. So this would open when your engine is cold, letting a bit more air in to start it up, but it will close after your engine is warm, even if it is still energized. Perhaps the RB has the same mechanism.
When (if) you find it, let us know where it is. I just started working on my wiring, so it will be a while before I can get to that.
Shane
