oleman »
https://forums.nicoclub.com/oleman-u200137.html
Fri Mar 09, 2012 1:09 pm
I swapped my original timing chain out a 140,000 miles because the oil passage to pump seals went out where the t-cover meets the block.
Now at the 230,000 the timing chain tensioners are very bad with no plastic left on long tensioner and much scrubed off the short side.
I am now pulling the head because it sounded like valves were contacting pistons when I shut it down.
The chain and gears look fine except where the backside has rubbed the tensioner plates.
I used a coyles kit the last time, thinking since coyles is good on domestic cars it should be good on the D21.
Is there a brand of chain kit for the 93 KDE engine that has been proven to be long lasting and reliable.
Appreciate all input.
