rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Thu May 05, 2005 10:34 am
Here is the deal:
While im driving at normal speeds, i touch the gas pedal to accelerate and the motor does not repond... I BARELY tap it like 1/4 inch and there is no repsonce from the motor until i push in the pedal in farther, then it goes, and when it does go, it has a slight hesitation, but then releases and goes full like normal..
This happens at all speeds and all gears....
For some reason its like the motor wont respond unless i hit the pedal farther than barely...
One other strange thing is while im watching the AFC, i noticed that my Throttle readout seems to be a bit higher than normal (while driving only)
I can sit there and start to press on the gas pedal and slowly push down as if i was accelerating and i can see the afc reading the throttle %... and for some reason when it reads 50% throttle i noticed that the pedal was NO WHERE NEAR 50%.....
But then when i let off completly, it goes back to zero like it should..
I changed out the MAF and i still have this problem which only leads me to the TPS next... cause i dont know what else controls throttle responce..
