Sushibandito »
https://forums.nicoclub.com/sushibandito-u133627.html
Wed Dec 09, 2009 6:50 pm
Edit: This is in the wrong section by mistake...
Didn't seem to be much for my particular problem, and its rather complicated, so hoping that someone has some advice...
I have a stock KA24DE with an auto transmission, 105k miles.
2-3 weeks ago my temp gauge went up to 1 bar short of High on a rather short drive to the grocery store. Parked the car, did my shopping, on the ride home temp gauge stayed at center. Didn't happen again for weeks.
2 days ago it went to High several times, so bought a new thermostat and swapped that out today. Bled the system correctly after figuring out where the bleeder screw was, was fairly certain that I got all the air out, although the temp gauge never left the bottom, stayed cold the entire time, even after 20 minutes. This is after at least an hour of the car being on jack-stands with the radiator cap off.
1st issue - The exhaust is pumping out a fair amount of white smoke that smells sweet, definitely coolant. 2nd issue - Some squealing on acceleration that has never been there before, and I didn't remove any belts to get the thermostat out. This may be entirely un-related, but not sure if it is somehow connected.3rd issue - The water pump is leaking tons of coolant, not sure if that is due to a gasket that went bad from pressurizing the cooling system without having first removed the bleeder screw?
Since I was working on the car at my brothers, on the drive home it stopped blowing coolant and the temp gauge reached normal, but I suspect that has more to do with the radiator burning through all its reserves. Will be checking fluid levels tomorrow morning. I also just changed the oil today to Mobil 1 synthetic, and I have heard rumors of this being a bad idea on an older car?
