Bad stuttering when downshifting into 2nd @ WOT.
guadofreak
Car: 1994 Q45t
I have noticed this only really happens when I Am doing about 50-80 and the car downshifts when I floor it to pull ahead in traffic.
1994 Q45t 153K miles
Usually only happens after the car has been running for over 15-20 minutes or so. It is very anooying. Also happens when I am in the higher rpms in 1st.
Any ideas? possibly transmission related? when the car is has only been running for about 5-10 minutes it runs perfect and like a champ!!
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Low fuel pressure? Failing pump or FPCU, clogged fuel filter.
DAEDALUS
Could be. Everytime you floor it you increase injector pressure 30% or so, in addition to duty cycle and pump voltage (3-speed pump). If the pump or FPCU is marginal it might be having trouble keeping up with demand. Problems with the FPCU have been known to show up only after running for a while, after the solder joints have had time to heat up.
guadofreak
Car: 1994 Q45t
interesting indeed. The fuel pump was replaced a while ago I have to check on the FPCU...
Aussie Q45
Car: 1990 Nissan Infinity Q45. '46 Ford Super Deluxe (Restored)
Hope you don't mind me asking a Q on your subject. My '89/90 Q45 is doing the same thing (97K's) and I am in the process of replacing the spark plugs. I noticed that you have 153K's up. Have your plugs been changed? Or am I hoping for a cheap fix and should I be looking elsewere for my problem. I have replaced the fuel filter. Where would I find the fuel pump and FPCU?
WOT=????????
911/Q45
1996 Porsche Turbo
You are right on the money for your plug change, 60K miles in US=97K klicks in AUS. The fuel pump is inside the tank and the FPCU is suspended above it. Your pump and FPCU should be good at your mileage(kilometerage?). WOT=wide open throttle.
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
guadofreak wrote:I have noticed this only really happens when I Am doing about 50-80 and the car downshifts when I floor it to pull ahead in traffic.
Any ideas?
Rev Limiter.
guadofreak
Car: 1994 Q45t
squeefoo wrote:Rev Limiter.
Definitely not the rev limiter. Also happens from 4.5K rpms up.
my plugs were changed 30K ago so i know those are ok. I think I am going to try a newer FPCU and see what happens.
