Bad strut?
Nightstalker
Car: 2007 Toyota X-Runner
1993 Toyota MR2
1989 Toyota MR2 S/C
1989 Nissan 240sx
Hey, i seem to be having a problem with my front left suspension.
If i take a right turn a little faster then normal, the tire hits and rubs the fender. I know its hitting the fender because where the fender liner bolts to the fender has cut into the tire a little. Also the middle of the tire is starting to get cut by something, i have to check that out prolly tomorrow.
But if i take a left turn a little to fast there is no problem, there is no rubbing on the right side.
Now today i check the shock to see if it was leaking and its not, perfectly dry.
What else could be causing this if the shock is not bad? Could the body be a little bend down on that side causing it to rub? I know the car was in a front end accident by the previous owner.
Any suggestions would help , thanks.
Cameron
Car: a 240
its prolly just a bad shock cause when i went up to the mountains mine was doing the same thing, turns out mine was a bad shock, i bout new ones now tho.
