nismo24T wrote:but i still hear a rapid clicking sound...still a bad starter?..u can tell i dont want to take this thing off..again...*pain*...just wanna make sure...btw...does autozone check starters?
If you haven't already, do what i suggested before. Save you the trouble of taking off the starter and then find out it wasn't the problem.
check around the wiring under the hood like around the fuse box to see if all the connections are ok. Like just jiggle them around. Also do a search on "car not starting" or something similar. I found numerous threads on this subject when my starter died on me
PGBrianIt was a pain changing it for me.... The bolts were freaking hard to turn cause i had no leverage while being under the car. The hardest one was probably the top bolt.
Modified by zer0c123 at 5:59 AM 12/9/2004
