BahamaMackhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=fd0e4e8a8dd1d2e077252d7be0670db2bad start to a vacationFri Dec 12, 2014 5:20 am
Postby
BahamaMack »
https://forums.nicoclub.com/bahamamack-u233824.htmlFri Dec 12, 2014 5:20 am
So im driving to the airport and as I pulled into the parking lot my front tires sound and feel as if they were dragging. And all of my dash board lights lite up l, the "slip" light and the caution light.
Any suggestions on what it may be.
im stressed right out this morning. ....urgh!!!
Postby
steve_c »
https://forums.nicoclub.com/steve-c-u163301.htmlFri Dec 12, 2014 6:33 am
Someone just recently posted on this forum that their front driveshaft broke. He submitted photos, it looks likes the sealed U joints may have seized up.
How many miles on your Fuga? Did you notice any wheel bearing noise prior to the problem?
The VDC/Slip lights are likely a reaction to your problem, I am thinking bearings or driveshaft problem could be a few causes.
Postby
LouCast »
https://forums.nicoclub.com/loucast-u222990.htmlFri Dec 12, 2014 8:15 am
Check your brake fluid, low brake fluid will cause the lights to turn on, Also if your car has no power it might be the camshaft sensor that is bad. Start with the simple stuff, check your brake fluid, if it's low then its time to change your pads.
