skrappy »
https://forums.nicoclub.com/skrappy-u84547.html
Mon Jan 28, 2008 5:33 pm
Ok a lot of what is posted could be wrong but i have felt this before and it sounds like its your subframe bushings. Take a look at them. Might wana upgrade to some solid bushings. their like 60 bucks. Also take a look at your pinnapple bushings and see how those look. Anything, bushing wise, in the rear end or up front that looks like its cracked needs to be replaced.
A rotor would have to be pretty ****ed up for the whole car to shake like an earthquake and the only way a motor or transmission would do it is if you had absolute solid mounts which i doubt you do from what you described. Driveshaft is highly unlikely. Driveshaft wont really get ****ed up unless you are pusing some insane torque, or if your drifting and just totally demolish it. I have seen stock driveshafts hold up to around 500+ ft lbs of torque. hope this helps. good luck
