bad rings?
95nismo240
Car: 1995 Nissan 240sx
i have a 95 nissan 240sx auto. i just had a used 96 engine swapped into it. i had no problems with it, except that i heard that the cat was making noise. i decided to just take the cat out and having the o2 sensor welded back on. when i started the car up and drove it for a little while i noticed a puff of bluish greyish smoke come out the tail pipe. i noticed that the smoke gets alot worse when the car is at normal temperature. i drove it like this for about a week or two cause i had to go to work. i checked the oil after and i had to add 3 quarts!! im thinking the rings are bad. i did a compression test when i put the engine in and all cylinders where around the same.
midnightsliding
what was your compression across .
240sx2nr
Car: 95' 240sx zenki
was the compression low? could be a number of things
95nismo240
i dont remember if it was 120 or around 160. but they were all around the same number.
hachibroku
Car: 98 240sx s14 MO Betta
The Compression max is 179 and the min is 151 with a tolerance of 14psi.
