Bad Rattle and Clanking Noises!
After sitting for 2 or 3 days, I started up my 92 Q. I heard this loud and scary clacking and clicking sound from the front area, not sure if it was under the hood or underneath.
After about 10 seconds, it faded away completely. Only once before have I heard this, on a 91 Q45T I test drove that had been sitting for two weeks.
I shut off the car and started it again, the sound was still gone.
Is this normal when a Q sits for a long time? I recently switched from Mobil 1 5W30 to Mobil 1 10W30. I tried 5W just once to see what would happen, and since nothing seemingly improved I switched back.
-Jesda
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Probably just some lifter noise from oil being drained down from the heads...... Once there was adequate oil pressure, it went away......
Thats my $.02, it may or may not be correct......
Im sure it scared the crap out of you!!! With your origional guides and all!!
Nismo_Freak
Car: 89 Nissan 240SX
Yeah... it's just a dry start. It's why your not supposed to let a car just sit.
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
All of my Nissans at one time or another has had some startup clatter (sr20de), what I do if my Q sits for a while is I actually pull the fuel pump fuse and then crank it a few just to get some oil in the top end before I start it, dont konw if its any better than just starting it but thats my lil method.:)
Isnt that bad for the crucial and expensive fuel control module?
DAEDALUS
Car: 1990 Infiniti Q45
Not at all. I would add that pulling the injector fuse is also a good thing in addition to the fuel pump fuse, to eliminate any residual fuel in the rails from being allowed into the combustion chambers.
Q451990
I just pull the injector fuse under the hood - no need to pull both... I wouldn't think a great deal of noise is normal. Maybe a little tapping for three or four seconds, but I'm afraid you're hearing guide rattle (was it more of a fluttering sound?) due to a bleed-down on the tensioners...
Heath
DAEDALUS
Q451990 wrote:I just pull the injector fuse under the hood - no need to pull both... Heath
I pull both in case one or more injectors have any leaks.
Q451990
Hmmm... never thought of that. Sounds like a good idea!
Heath
elwesso
2007 BMW M Coupe
I dont let my Q sit for that long :D
